Einleitung
This guide will walk you through the process of replacing a broken camera in a Samsung Gear 2.
Was du brauchst
To remove each strap, locate the metal latches on both sides of the back of the Gear.
Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
Pry the device open from the other side also if it does not fully disassemble from one side.
2 weitere Personen haben diese Anleitung absolviert.
