Zum Hauptinhalt wechseln
Samsung Gear 2 Camera Replacement
Was du brauchst
  1. Samsung Gear 2 Camera Replacement, Front half and Back half: Schritt 1, Bild 1 von 2 Samsung Gear 2 Camera Replacement, Front half and Back half: Schritt 1, Bild 2 von 2
    • Before disassembling your Gear, be sure it is powered off.
    • To remove each strap, locate the metal latches on both sides of the back of the Gear.
    • Press down on the metal latch while pulling the strap away from the Gear until it is completely off.
  2. Samsung Gear 2 Camera Replacement: Schritt 2, Bild 1 von 1
    • Remove the four 4.0 mm screws on the back of the Gear using a T5 Torx Screwdriver.
  3. Samsung Gear 2 Camera Replacement: Schritt 3, Bild 1 von 3 Samsung Gear 2 Camera Replacement: Schritt 3, Bild 2 von 3 Samsung Gear 2 Camera Replacement: Schritt 3, Bild 3 von 3
    • Firmly holding the Gear, insert the flat side of the spudger at an angle to pry the back casing off of the device. Move the spudger along the sides of the Gear to completely detach the back and front components.
    • Pry the device open from the other side also if it does not fully disassemble from one side.
  4. Samsung Gear 2 Camera Replacement, Camera: Schritt 4, Bild 1 von 2 Samsung Gear 2 Camera Replacement, Camera: Schritt 4, Bild 2 von 2
    • Locate the rectangular metal connector that attaches the camera to the Gear.
    • Use tweezers to gently lift and detach the metal plate of the connector.
    • When reassembling the Gear, reattach the camera connector by carefully aligning the metal plate and its pins to its original placement. Make sure it snaps in place to avoid improper connections and possible damage.
  5. Samsung Gear 2 Camera Replacement: Schritt 5, Bild 1 von 1
    • Use tweezers to carefully lift the camera from its slot out of the case.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Allison Michel
513 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 13-27, Maness Spring 2014 Mitglied von Cal Poly, Team 13-27, Maness Spring 2014
CPSU-MANESS-S14S13G27
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Hey cool! Were can i buy the camara?
jorge - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 5
Insgesamt: 3,606
