Zum Hauptinhalt wechseln
Samsung Gear 360 Front Camera Replacement
Was du brauchst
  1. Samsung Gear 360 Front Camera Replacement, Case: Schritt 1, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement, Case: Schritt 1, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement, Case: Schritt 1, Bild 3 von 3
    • Twist silver ring on the lens counter-clockwise with force to remove it.
  2. Samsung Gear 360 Front Camera Replacement: Schritt 2, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 2, Bild 2 von 2
    • Insert a small flathead screwdriver into marked slot on camera lens and pry off camera lens cover.
  3. Samsung Gear 360 Front Camera Replacement: Schritt 3, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 3, Bild 2 von 2
    • Using a PH00 screwdriver head, remove all Phillips #00 0.75 mm screws on the front of the camera.
    • Repeat for the back side of the camera.
  4. Samsung Gear 360 Front Camera Replacement: Schritt 4, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 4, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 4, Bild 3 von 3
    • Peel off the black rubber located on the bottom of the device using your hand or a small flathead screwdriver.
  5. Samsung Gear 360 Front Camera Replacement: Schritt 5, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 5, Bild 2 von 2
    • Once the black rubber has been removed, unscrew all Phillips #00 0.75 mm screws on the bottom of the device using a PH00 screwdriver head.
  6. Samsung Gear 360 Front Camera Replacement: Schritt 6, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 6, Bild 2 von 2
    • Using a plastic opening tool, pry the tripod mount off the device.
  7. Samsung Gear 360 Front Camera Replacement: Schritt 7, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 7, Bild 2 von 2
    • Using both hands, carefully remove the right cover off the camera body.
  8. Samsung Gear 360 Front Camera Replacement: Schritt 8, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 8, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 8, Bild 3 von 3
    • To remove the left cover of the camera body, lift the left cover using a small flathead screwdriver and pull it off.
  9. Samsung Gear 360 Front Camera Replacement: Schritt 9, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 9, Bild 2 von 2
    • Once the camera body has been removed, lift and pull off the metal support ring using a small flathead screwdriver.
    • Repeat for both sides of the camera.
  10. Samsung Gear 360 Front Camera Replacement: Schritt 10, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 10, Bild 2 von 2
    • Remove all Phillips #00 0.75 mm screws from the body of the camera using a PH00 screwdriver head.
  11. Samsung Gear 360 Front Camera Replacement: Schritt 11, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 11, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 11, Bild 3 von 3
    • Carefully lift the three sensors off using a plastic opening tool and pull them aside.
  12. Samsung Gear 360 Front Camera Replacement: Schritt 12, Bild 1 von 2 Samsung Gear 360 Front Camera Replacement: Schritt 12, Bild 2 von 2
    • Carefully use a plastic opening tool to separate the gray case from the black case on the device.
  13. Samsung Gear 360 Front Camera Replacement: Schritt 13, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 13, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 13, Bild 3 von 3
    • Insert a plastic removal tool underneath the four sensors on the motherboard to fully separate the camera case.
  14. Samsung Gear 360 Front Camera Replacement, Speaker: Schritt 14, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement, Speaker: Schritt 14, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement, Speaker: Schritt 14, Bild 3 von 3
    • Within gold metal half of the case, unscrew the Phillips #00 0.75 mm screw located on the metal plate using a PH00 screwdriver.
    • Using a plastic opening tool, remove the metal cover.
  15. Samsung Gear 360 Front Camera Replacement: Schritt 15, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 15, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement: Schritt 15, Bild 3 von 3
    • Using a PH000 screwdriver head, unscrew all Phillips #00 0.75 mm screws.
    • To remove the speaker from the device, use a plastic opening tool on the edge and gently lift it up.
  16. Samsung Gear 360 Front Camera Replacement, Front Camera: Schritt 16, Bild 1 von 3 Samsung Gear 360 Front Camera Replacement, Front Camera: Schritt 16, Bild 2 von 3 Samsung Gear 360 Front Camera Replacement, Front Camera: Schritt 16, Bild 3 von 3
    • Using a PH000 screwdriver head, unscrew both screws on the remaining case.
    • Use a plastic opening tool to lift the front camera module from the case.
Abschluss
Connor
454 Reputation
3 Anleitungen geschrieben
USF Tampa, Team S3-G5, Sullivan Spring 2017 Mitglied von USF Tampa, Team S3-G5, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G5
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 851
