Einleitung
The Samsung Gear 360 does not come included with a memory card, so an additional MicroSD card is required to use the device. It is recommended to use a class 10 MicroSD card with a maximum of 256GB of storage.
Was du brauchst
Begin by turning the Gear 360 to the side where Samsung is printed.
Pull on the small gap to open the cover. If your fingernails are too short, use a flathead screwdriver instead.
Eject the SD by pushing with your fingernail or flathead screwdriver.
To insert a new card, follow the guide in reverse.
100%
Hier starten ›
