Einleitung
The watch contains a small, 300mAh lithium-ion battery. Though these batteries will generally last for years, they do have a limit to the number of times they can be charged. As the battery grows older and is charged repeatedly, it may become less and less able to hold a charge. When this happens, replace the battery.
Was du brauchst
Press the watchband down against the work surface.
Press the tip of a flathead screwdriver against the edge of the spring-loaded holding pin.
With the spring-loaded pin pressed in, the watch band should release easily.
Gently pull the band away from the body of the watch.
Repeat steps 2 and 3 for the opposite side.
With the watch laying face-down, locate the four screws. They are located on the back of the watch, at the four corners.
Using a Torx-T5 screwdriver, remove each of the four 4mm screws and set them aside.
Gently work the plastic opening tool under the top edge of the watch’s back cover.
With the watch’s back cover pried loose, gently lift it away from the front half of the watch.
Lay both halves of the watch body assembly face down (with internal components facing up).
Locate the battery on the back half of the disassembled watch body. It is rectangular in shape and located just above the window for the heart monitor.
Locate the battery’s electrical contacts. They are located next to the heart rate monitor. They roughly form a “+” shape.
Using the plastic opening tool, gently pry the contacts away from the plastic channel in which they fit.
Gently work the plastic opening tool under the battery.
Using the plastic opening tool, gently pry the battery up.
13 weitere Personen haben diese Anleitung absolviert.
7 Kommentare
This is neat and helpful, but where do I find a replacement battery?
Where can I purchase these batteries?
I purchased my battery on eBay.
Jay -
