Einleitung
This guide will show step by step instructions on how to replace the Samsung Gear S speaker.
Was du brauchst
Remove the wrist strap by peeling back the rubber starting from one corner of the watch face. Continue peeling the rubber away from the watch face until the strap is completely off.
Starting from an edge, wedge a metal spudger in between the screen and the chrome trim ring and pry, lifting the screen outwards.
Use a plastic opening tool to gently pry upwards on the plastic motherboard assembly.
Use a plastic opening tool to detach the glass screen/ LED Display ribbon connector from the motherboard.
Locate the speaker in the upper left corner of the housing.
Locate the speaker ribbon connector directly below the speaker.
Use the plastic opening tool to gently pry upwards on the speaker's ribbon connector.
3 weitere Nutzer:innen haben diese Anleitung absolviert.
2 Kommentare
Do you have a place where we can buy the speaker part?
