Einleitung
Has the buckle on the strap of your watch become broken, or do you just want to replace the factory strap with a custom one? Just swap it out.
Was du brauchst
Flip the watch over so that the face is down.
Using a Y#0 screwdriver, unscrew the four 3.5 millimeter tri-head screws.
7 weitere Nutzer:innen haben diese Anleitung absolviert.
6 Kommentare
can you also provide instruction to change home button on Gear S2
thanks
Where can you buy new straps?
Ebay Amazon etc.
YOU DO NOT NEED TO REMOVE THE SCREWS. Step 1 is completely irrelevant.
