Was du brauchst
Einführungsvideo
Angehängtes Dokument
Locate the small push tabs on the back of the wrist straps, pushing them in to release the wrist strap.
Remove any casing or housing on the watch, and clean any dust/debris.
(Black lines are used for privacy)
Using a Tri-point screwdriver, unscrew the four (4) back screws. Note: The case screws may remain in their place.
Using a metal jimmy, and a little bit of force, push down then lever it up to pop out the case.
Detatch the three (3) ribbons carefully with a plastic spudger. The ribbons to detach is black, yellow, & blue. You should feel a little click when re-attaching later. Note: These parts are very delicate so exercise caution!
Prying up from the corner with the red arrow, lift the motherboard and maneuver the ribbons out of the opening making sure not to tug or rip them.
Remove two Phillips head screws before moving on.
Make sure to have the two Phillips head screws completely removed before attempting the following steps.
Pressing on the small black plastic area will give you leverage to pull off the motherboard gently.
Do NOT flip the motherboard without first detaching the battery's ribbon. The motherboard will still be connected by a ribbon. Only the battery's ribbon will be detached (Marked by the red arrow in the second photo). Using a flat tool to get underneath the ribbon will lift it up allowing you to flip the motherboard over.
The original battery will most likely be attached to the motherboard. A spudger will be needed to detach the battery from the motherboard. Note: Use caution, gently inserting and lifting as it allows. Use of any sharp or pointed tools can rupture the battery and will cause it to burst.
Insert the new battery and test for power.
Remember to recycle your used batteries!
11 weitere Nutzer:innen haben diese Anleitung absolviert.
Angehängte Dokumente
5 Kommentare
Not a comment but a question: What happens with the waterproofing of the watch with this?
Of course with a take apart of any device the waterproofing will be gone unfortunately.
Id heavily consider rewriting step 4. I almost pried the board off with the screws still attached because I read from left to right on the pictures. Device is okay but I was assuming an entire unit attached with screws was coming out of a shell. Good guide otherwise, thanks
Question - Is this the same procedure for the Frontier model of the S3?
A bit of a challenge for someone at the age of 63. But it worked out. Screws should be off before lifting the mainboard (step 4).
