Zum Hauptinhalt wechseln
Samsung Gear VR Motherboard Replacement
Was du brauchst
  1. Samsung Gear VR  Motherboard Replacement, Front Phone Mount: Schritt 1, Bild 1 von 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: Schritt 1, Bild 2 von 3 Samsung Gear VR  Motherboard Replacement, Front Phone Mount: Schritt 1, Bild 3 von 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR  Motherboard Replacement: Schritt 2, Bild 1 von 2 Samsung Gear VR  Motherboard Replacement: Schritt 2, Bild 2 von 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR  Motherboard Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR  Motherboard Replacement: Schritt 4, Bild 1 von 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
Abschluss
USF Tampa, Team S4-G6, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Mitglieder
7 Anleitungen geschrieben
Ein Kommentar
Any idea where I can get a replacement board? Searched but cant seem to find. Thanks!
bineesh2k - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 11
Insgesamt: 1,522
