Zum Hauptinhalt wechseln
Samsung Gear VR Front Phone Mount Replacement
Was du brauchst
  1. Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: Schritt 1, Bild 1 von 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: Schritt 1, Bild 2 von 3 Samsung Gear VR Front Phone Mount Replacement, Front Phone Mount: Schritt 1, Bild 3 von 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Front Phone Mount Replacement: Schritt 2, Bild 1 von 2 Samsung Gear VR Front Phone Mount Replacement: Schritt 2, Bild 2 von 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
USF Tampa, Team S4-G6, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 9
Insgesamt: 1,257
