Zum Hauptinhalt wechseln
Samsung Gear VR Inner Mask Replacement
Was du brauchst
  1. Samsung Gear VR Inner Mask Replacement, Front Phone Mount: Schritt 1, Bild 1 von 3 Samsung Gear VR Inner Mask Replacement, Front Phone Mount: Schritt 1, Bild 2 von 3 Samsung Gear VR Inner Mask Replacement, Front Phone Mount: Schritt 1, Bild 3 von 3
    • Remove the front cover to access a plate that holds the phone in place during use.
    • Remove the four corner screw covers with a metal spudger to reveal four screws.
    • Remove the sticker located at the top center to reveal two additional screws.
  2. Samsung Gear VR Inner Mask Replacement: Schritt 2, Bild 1 von 2 Samsung Gear VR Inner Mask Replacement: Schritt 2, Bild 2 von 2
    • Using the PH000 tip remove the six 0.5 cm screws that secure the front phone mount.
    • After the six 0.5 cm screws are completely removed lift the front phone mount up and to the left.
    • When handling your equipment be careful not to strain the wire harness located on the left side of the headset.
  3. Samsung Gear VR Inner Mask Replacement, Motherboard: Schritt 3, Bild 1 von 1
    • Use the blue plastic opening tool to remove the rest of the the pop connectors from the motherboard.
    • The larger gold connector is lightly glued down so it may take more effort to remove than the others.
  4. Samsung Gear VR Inner Mask Replacement: Schritt 4, Bild 1 von 1
    • You can now remove the motherboard from the mask.
    • Make sure that nothing is connected to the motherboard before you try to remove it as pulling it with something connect might brake the connections.
  5. Samsung Gear VR Inner Mask Replacement, Inner Mask: Schritt 5, Bild 1 von 3 Samsung Gear VR Inner Mask Replacement, Inner Mask: Schritt 5, Bild 2 von 3 Samsung Gear VR Inner Mask Replacement, Inner Mask: Schritt 5, Bild 3 von 3
    • Using the PH000 tip remove the eight 0.5 cm screws from the Inner Mask
    • Carefully remove the Inner Mask by pulling it from the inner side of the lenses socket.
Abschluss
USF Tampa, Team S4-G6, Eyestone Fall 2017 Mitglied von USF Tampa, Team S4-G6, Eyestone Fall 2017
USFT-EYESTONE-F17S4G6
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 12
Insgesamt: 571
