Zum Hauptinhalt wechseln
Samsung Gear VR With Controller Trackpad Replacement
Was du brauchst
  1. Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: Schritt 1, Bild 1 von 3 Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: Schritt 1, Bild 2 von 3 Samsung Gear VR With Controller Trackpad Replacement, Inner Mask: Schritt 1, Bild 3 von 3
    • Push the switch on the right-hand side of the device to separate the cover from the main body.
    • Pull the cover away from the main device.
  2. Samsung Gear VR With Controller Trackpad Replacement: Schritt 2, Bild 1 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 2, Bild 2 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 2, Bild 3 von 3
    • Remove the four corner screw covers with a metal spudger.
    • The screw covers fly off when removed, so make sure to keep track of them.
  3. Samsung Gear VR With Controller Trackpad Replacement: Schritt 3, Bild 1 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 3, Bild 2 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 3, Bild 3 von 3
    • Use a metal spudger to remove the screw cover centered at the top.
  4. Samsung Gear VR With Controller Trackpad Replacement: Schritt 4, Bild 1 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 4, Bild 2 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 4, Bild 3 von 3
    • Remove the six 5mm Phillips #000 screws to detach the front phone mount.
    • Lift the front phone mount up and to the left.
    • Remove the front phone mount carefully because there is a wire harness on the left side of the headset.
  5. Samsung Gear VR With Controller Trackpad Replacement: Schritt 5, Bild 1 von 2 Samsung Gear VR With Controller Trackpad Replacement: Schritt 5, Bild 2 von 2
    • Remove the four 5mm Phillips #000 screws that secure the plate on the left side of the headset.
    • Pull the plate away from the motherboard gently.
  6. Samsung Gear VR With Controller Trackpad Replacement: Schritt 6, Bild 1 von 2 Samsung Gear VR With Controller Trackpad Replacement: Schritt 6, Bild 2 von 2
    • Use the iFixit opening tool to remove the pop connector holding the wire harness to the motherboard.
    • You can now completely remove the front phone mount from the headset.
  7. Samsung Gear VR With Controller Trackpad Replacement: Schritt 7, Bild 1 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 7, Bild 2 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 7, Bild 3 von 3
    • Remove the rest of the pop connectors on the motherboard using the iFixit opening tool.
    • Pry at the top of the motherboard with the iFixit opening tool to remove the motherboard.
    • The largest pop connector may require more effort to remove.
    • Make sure that nothing is connected to the motherboard before you pull it out.
  8. Samsung Gear VR With Controller Trackpad Replacement: Schritt 8, Bild 1 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 8, Bild 2 von 3 Samsung Gear VR With Controller Trackpad Replacement: Schritt 8, Bild 3 von 3
    • Remove the eight 5mm Phillips #000 screws on the inner mask.
    • Gently separate the inner mask from the headset by pulling the mask from the inner sides of the lens sockets.
  9. Samsung Gear VR With Controller Trackpad Replacement, Trackpad: Schritt 9, Bild 1 von 3 Samsung Gear VR With Controller Trackpad Replacement, Trackpad: Schritt 9, Bild 2 von 3 Samsung Gear VR With Controller Trackpad Replacement, Trackpad: Schritt 9, Bild 3 von 3
    • Remove the one 5mm Phillips #000 screw to detach the trackpad from the headset.
    • Pry the trackpad loose from the headset using the spudger.
Abschluss
Eine weitere Person hat diese Anleitung absolviert.
Cal Poly, Team S18-G3, White Winter 2019 Mitglied von Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 8
Insgesamt: 352
