Zum Hauptinhalt wechseln
Samsung Gear VR with Controller Motherboard Replacement
Was du brauchst
    1. Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: Schritt 1, Bild 1 von 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: Schritt 1, Bild 2 von 3 Samsung Gear VR with Controller Motherboard Replacement, Controller Batteries: Schritt 1, Bild 3 von 3
      • Turn the controller upside down to access the battery compartment.
      • The battery compartment is located on the opposite side of the buttons.
      • Press on the top of the battery plate and slide down to remove the cover.
      Frag FixBot
      Kommentar hinzufügen
    2. Samsung Gear VR with Controller Motherboard Replacement: Schritt 2, Bild 1 von 3 Samsung Gear VR with Controller Motherboard Replacement: Schritt 2, Bild 2 von 3 Samsung Gear VR with Controller Motherboard Replacement: Schritt 2, Bild 3 von 3
      • Remove the AAA batteries using your fingers.
      Frag FixBot
    1. Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: Schritt 3, Bild 1 von 2 Samsung Gear VR with Controller Motherboard Replacement, Controller Motherboard: Schritt 3, Bild 2 von 2
      • Remove the four 5mm Phillips #000 screws.
      Frag FixBot
    2. Samsung Gear VR with Controller Motherboard Replacement: Schritt 4, Bild 1 von 1
      • Use the metal spudger to pry the back side of the controller apart from the front.
      • You will have to use the spudger in many different spots along the divide before trying to separate the pieces.
      Frag FixBot
    3. Samsung Gear VR with Controller Motherboard Replacement: Schritt 5, Bild 1 von 2 Samsung Gear VR with Controller Motherboard Replacement: Schritt 5, Bild 2 von 2
      • Pull apart the two halves of the controller to access the motherboard.
      Frag FixBot
    4. Samsung Gear VR with Controller Motherboard Replacement: Schritt 6, Bild 1 von 3 Samsung Gear VR with Controller Motherboard Replacement: Schritt 6, Bild 2 von 3 Samsung Gear VR with Controller Motherboard Replacement: Schritt 6, Bild 3 von 3
      • Pry on the two pop connectors with the plastic opening tool to detach the motherboard.
      • Separate the motherboard and trackpad from the rear part of the controller.
      Frag FixBot
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Cal Poly, Team S18-G3, White Winter 2019 Mitglied von Cal Poly, Team S18-G3, White Winter 2019
CPSU-WHITE-W19S18G3
4 Mitglieder
84 Anleitungen geschrieben
0 Kommentare zur Anleitung
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 26
Insgesamt: 1,347
