Zum Hauptinhalt wechseln
Samsung Glyde Antenna Replacement
Was du brauchst
  1. Samsung Glyde Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Using your thumb, press down and slide the back cover away from the camera.
  2. Samsung Glyde Antenna Replacement: Schritt 2, Bild 1 von 1
    • Remove the battery from the phone by using your plastic opening tool to find a gap at any edge of the battery and lifting the battery up.
  3. Samsung Glyde Antenna Replacement, Antenna: Schritt 3, Bild 1 von 2 Samsung Glyde Antenna Replacement, Antenna: Schritt 3, Bild 2 von 2
    • Using a Phillips #00 screwdriver, remove the six 4mm screws holding the back case together.
  4. Samsung Glyde Antenna Replacement: Schritt 4, Bild 1 von 2 Samsung Glyde Antenna Replacement: Schritt 4, Bild 2 von 2
    • Use a plastic opening tool to pry the case off. To do this, find a gap on any side of the phone, top preferably, and slip the tip of the tool in the gap.
    • Now use moderate strength and slowly maneuver the tool around the outside until the case becomes loose.
    • Using your fingers, take the case off.
  5. Samsung Glyde Antenna Replacement: Schritt 5, Bild 1 von 2 Samsung Glyde Antenna Replacement: Schritt 5, Bild 2 von 2
    • The antenna is located on the bottom of the phone. It is the small rectangular shaped object sticking out on one of the ends.
    • Use a plastic opening tool to prop the antenna out. To do so, slip the tip of the tool on one of the edges of the antenna. Use moderate pressure to pry the antenna out.
  6. Samsung Glyde Antenna Replacement: Schritt 6, Bild 1 von 2 Samsung Glyde Antenna Replacement: Schritt 6, Bild 2 von 2
    • Using a plastic opening tool, disconnect the connector leading from the antenna to the phone.
Abschluss
Cameron Law
142 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 3-12, Regan Fall 2011 Mitglied von Cal Poly, Team 3-12, Regan Fall 2011
CPSU-REGAN-F11S3G12
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,113
