Einleitung
Prerequisite Only
Was du brauchst
Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
Insert your finger in the groove below the battery.
Press the battery toward the audio jack while lifting upward and away from the phone.
Using your finger, push the SIM Card down and slide out of the slot.
Remove the SIM card away from the phone.
Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
After the click, release the microSD card to allow it to pop out.
Remove the microSD card from its slot
Remove the six 3 mm #00 Phillips screws in the plastic back frame.
Slide the keyboard out.
Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
Lift the plastic back frame away.
