Zum Hauptinhalt wechseln
Samsung Gravity TXT SIM Card Replacement
Was du brauchst
  1. Samsung Gravity TXT SIM Card Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Gravity TXT SIM Card Replacement, Battery: Schritt 1, Bild 2 von 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT SIM Card Replacement: Schritt 2, Bild 1 von 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT SIM Card Replacement: Schritt 3, Bild 1 von 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT SIM Card Replacement, SIM Card: Schritt 4, Bild 1 von 3 Samsung Gravity TXT SIM Card Replacement, SIM Card: Schritt 4, Bild 2 von 3 Samsung Gravity TXT SIM Card Replacement, SIM Card: Schritt 4, Bild 3 von 3
    • Using your finger, push the SIM Card down and slide out of the slot.
    • Slide the SIM card out enough to grab it firmly.
    • Remove the SIM card away from the phone.
    • Follow the visual on the bottom of the SIM card slot to put the SIM card back in the correct orientation.
    • When sliding the SIM Card back in the slot, make sure the card goes all the way in the slot until it hits the stopper.
Abschluss
IUPUI, Team 1-1, Renguette SU 2015 Mitglied von IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 3
Letzte 30 Tage: 11
Insgesamt: 845
