Was du brauchst
Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
Insert your finger in the groove below the battery.
Press the battery toward the audio jack while lifting upward and away from the phone.
Using your finger, push the SIM Card down and slide out of the slot.
Remove the SIM card away from the phone.
Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
After the click, release the microSD card to allow it to pop out.
Remove the microSD card from its slot
Remove the six 3 mm #00 Phillips screws in the plastic back frame.
Slide the keyboard out.
Use a Jimmy to separate a small segment of the plastic back frame from rest of the phone.
Slide an opening pick around the rest of the seam, starting at the gap just created with the Jimmy.
Lift the plastic back frame away.
Remove the two 3 mm Phillips #00 screws securing the motherboard to the front panel.
Use your finger nail to disconnect the display data cable from the motherboard.
Lift the ribbon off the plastic inner frame.
Remove the six 1.2 mm #00 screws from the inner plastic frame.
Slide the ribbon through the slot on the inner frame while pulling the frame away.
Use a opening pick to separate the plastic back casing from the front of the phone by running it along the seam between the two.
Lift casing slightly away while sliding the ribbon through the slot in the casing.
Remove the plastic adhesive sheet to expose the ribbon cables
Use your finger or a spudger to pull the screen ribbon out of the connector
Use a Jimmy to separate the screen from the rest of the phone
Lift the screen away
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
