Zum Hauptinhalt wechseln
Samsung Gravity TXT microSD Card Replacement
Was du brauchst
  1. Samsung Gravity TXT microSD Card  Replacement, Battery: Schritt 1, Bild 1 von 2 Samsung Gravity TXT microSD Card  Replacement, Battery: Schritt 1, Bild 2 von 2
    • Pry the back cover off with a plastic opening tool, or your fingernail, in the indentation on the bottom of the device.
  2. Samsung Gravity TXT microSD Card  Replacement: Schritt 2, Bild 1 von 1
    • Lift the back cover away from the main body of the phone.
  3. Samsung Gravity TXT microSD Card  Replacement: Schritt 3, Bild 1 von 1
    • Insert your finger in the groove below the battery.
    • Press the battery toward the audio jack while lifting upward and away from the phone.
    • Remember to place the battery back with the copper contacts on the battery lined up with those on the phone.
  4. Samsung Gravity TXT microSD Card  Replacement, microSD Card: Schritt 4, Bild 1 von 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: Schritt 4, Bild 2 von 3 Samsung Gravity TXT microSD Card  Replacement, microSD Card: Schritt 4, Bild 3 von 3
    • Using your fingernail, push the microSD card slightly deeper into the slot, until you hear a click.
    • The removal of the battery is not required for this operation; therefore, step 3 can be skipped if just replacing the microSD card.
    • After the click, release the microSD card to allow it to pop out.
    • Remove the microSD card from its slot
    • When placing the microSD card back in the phone, make sure the card clicks in place.
Abschluss
IUPUI, Team 1-1, Renguette SU 2015 Mitglied von IUPUI, Team 1-1, Renguette SU 2015
IUPUI-RENGUETTE-SU15S1G1
5 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 249
