Zum Hauptinhalt wechseln
Samsung HMX-F90 Lens Replacement
Was du brauchst
  1. Samsung HMX-F90 Lens Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung HMX-F90 Lens Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung HMX-F90 Lens Replacement, Battery: Schritt 1, Bild 3 von 3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: Schritt 2, Bild 1 von 2 Samsung HMX-F90 Lens Replacement, Strap Side Outer Casing: Schritt 2, Bild 2 von 2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Lens Replacement: Schritt 3, Bild 1 von 2 Samsung HMX-F90 Lens Replacement: Schritt 3, Bild 2 von 2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Lens Replacement: Schritt 4, Bild 1 von 2 Samsung HMX-F90 Lens Replacement: Schritt 4, Bild 2 von 2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Lens Replacement: Schritt 5, Bild 1 von 3 Samsung HMX-F90 Lens Replacement: Schritt 5, Bild 2 von 3 Samsung HMX-F90 Lens Replacement: Schritt 5, Bild 3 von 3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Lens Replacement, Lens: Schritt 6, Bild 1 von 2 Samsung HMX-F90 Lens Replacement, Lens: Schritt 6, Bild 2 von 2
    • Rotate the camcorder so that back is facing you. Then flip open the LCD screen.
    • Locate and remove the 4.5mm Phillips #00 screws in the LCD screen base.
  7. Samsung HMX-F90 Lens Replacement: Schritt 7, Bild 1 von 2 Samsung HMX-F90 Lens Replacement: Schritt 7, Bild 2 von 2
    • Close the LCD screen. Then lift the silver base away from the camcorder.
  8. Samsung HMX-F90 Lens Replacement: Schritt 8, Bild 1 von 2 Samsung HMX-F90 Lens Replacement: Schritt 8, Bild 2 von 2
    • Locate and remove the two 3.5mm Phillips #00 screws from the side of the camcorder.
  9. Samsung HMX-F90 Lens Replacement: Schritt 9, Bild 1 von 3 Samsung HMX-F90 Lens Replacement: Schritt 9, Bild 2 von 3 Samsung HMX-F90 Lens Replacement: Schritt 9, Bild 3 von 3
    • Gradually pry off the outer casing using a prying tool.
  10. Samsung HMX-F90 Lens Replacement: Schritt 10, Bild 1 von 3 Samsung HMX-F90 Lens Replacement: Schritt 10, Bild 2 von 3 Samsung HMX-F90 Lens Replacement: Schritt 10, Bild 3 von 3
    • Locate and remove the three 4mm Phillips #00 screws around the lens.
    • Gently remove the lens.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Amir Harb
705 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S13-G1, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 6
Letzte 30 Tage: 28
Insgesamt: 1,182
