Zum Hauptinhalt wechseln
Samsung HMX-F90 Strap Replacement
Was du brauchst
  1. Samsung HMX-F90 Strap Replacement, Battery: Schritt 1, Bild 1 von 3 Samsung HMX-F90 Strap Replacement, Battery: Schritt 1, Bild 2 von 3 Samsung HMX-F90 Strap Replacement, Battery: Schritt 1, Bild 3 von 3
    • Pull the release tab away from the battery.
    • Slide the battery towards the release tab and then pull the battery away from the camcorder.
  2. Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: Schritt 2, Bild 1 von 2 Samsung HMX-F90 Strap Replacement, Strap Side Outer Casing: Schritt 2, Bild 2 von 2
    • Rotate the camcorder so that the strap side is facing you.
    • Locate and remove the three 4.5mm Phillips #00 screws around the hand strap.
  3. Samsung HMX-F90 Strap Replacement: Schritt 3, Bild 1 von 2 Samsung HMX-F90 Strap Replacement: Schritt 3, Bild 2 von 2
    • Rotate the camcorder so that the battery slot is facing you.
    • Located in the top left corner of the battery slot, remove the 4.5mm Phillips #00 screw.
  4. Samsung HMX-F90 Strap Replacement: Schritt 4, Bild 1 von 2 Samsung HMX-F90 Strap Replacement: Schritt 4, Bild 2 von 2
    • Rotate the camcorder so you are looking at the bottom of the camcorder.
    • Locate and remove the last three 4.5mm Phillips #00 screws.
  5. Samsung HMX-F90 Strap Replacement: Schritt 5, Bild 1 von 3 Samsung HMX-F90 Strap Replacement: Schritt 5, Bild 2 von 3 Samsung HMX-F90 Strap Replacement: Schritt 5, Bild 3 von 3
    • With both hands, pull the side strap apart from the rest of the camcorder.
  6. Samsung HMX-F90 Strap Replacement, Hand Strap: Schritt 6, Bild 1 von 3 Samsung HMX-F90 Strap Replacement, Hand Strap: Schritt 6, Bild 2 von 3 Samsung HMX-F90 Strap Replacement, Hand Strap: Schritt 6, Bild 3 von 3
    • Unfasten the strap from the outside.
    • Pull apart the velcro on the faux leather strap sheath to reveal the separate end of the strap.
    • The loose end can be pulled off the velcro and fed through the loop on the casing to free one end of the strap.
  7. Samsung HMX-F90 Strap Replacement: Schritt 7, Bild 1 von 3 Samsung HMX-F90 Strap Replacement: Schritt 7, Bild 2 von 3 Samsung HMX-F90 Strap Replacement: Schritt 7, Bild 3 von 3
    • On the inside of the opened case, locate the silver metal plate and remove the 3mm Phillips screw.
    • Feed the strap through the hole to remove completely so that it can be replaced or cleaned.
Abschluss
Amir Harb
705 Reputation
6 Anleitungen geschrieben
USF Tampa, Team S13-G1, Boczar Fall 2017 Mitglied von USF Tampa, Team S13-G1, Boczar Fall 2017
USFT-BOCZAR-F17S13G1
4 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 18
Insgesamt: 294
