Zum Hauptinhalt wechseln
Samsung HMX-QF20 Internal Microphone Replacement
Was du brauchst
  1. Samsung HMX-QF20 Internal Microphone Replacement, Lens: Schritt 1, Bild 1 von 1
    • Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
  2. Samsung HMX-QF20 Internal Microphone Replacement: Schritt 2, Bild 1 von 1
    • Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
  3. Samsung HMX-QF20 Internal Microphone Replacement: Schritt 3, Bild 1 von 1
    • Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
  4. Samsung HMX-QF20 Internal Microphone Replacement: Schritt 4, Bild 1 von 1
    • Firmly grip and pull the front casing on the lens to remove it.
    • Be sure to remove the front casing at gently as possible to prevent damaging the attached ribbon cable. If not careful, the ribbon cables could be torn.
  5. Samsung HMX-QF20 Internal Microphone Replacement: Schritt 5, Bild 1 von 1
    • Remove the three 5 mm screws surrounding the lens.
Abschluss
Ian Dorset
225 Reputation
2 Anleitungen geschrieben
Marist, Team 1-5, Laflen Spring 2015 Mitglied von Marist, Team 1-5, Laflen Spring 2015
MARS-LAFLEN-S15S1G5
3 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 2
Letzte 30 Tage: 12
Insgesamt: 416
