Einleitung
Before replacing the lens cover, check to make sure the switch on the side is not temporarily stuck. If not and your lens cover is in need of replacement, follow this guide.
Was du brauchst
Remove the 4 mm screw on the underside of the camcorder near the tripod mount.
Remove the 4 mm screw next to the buckle of the hand strap closest to the lens.
Open the LCD screen. Remove the 4 mm screw on the inside panel, located at top left corner.
Eine weitere Person hat diese Anleitung absolviert.
