Zum Hauptinhalt wechseln
Samsung HMX-W200 Camera Lens Replacement
Was du brauchst
  1. Samsung HMX-W200 Camera Lens Replacement, Outer Case: Schritt 1, Bild 1 von 1
    • Remove the 5.00mm screw on the right of the LCD display towards the bottom of the device by using a Phillips #00 screwdriver.
  2. Samsung HMX-W200 Camera Lens Replacement: Schritt 2, Bild 1 von 3 Samsung HMX-W200 Camera Lens Replacement: Schritt 2, Bild 2 von 3 Samsung HMX-W200 Camera Lens Replacement: Schritt 2, Bild 3 von 3
    • Use the plastic opening tool to separate and remove the bottom red casing. Do this by, pushing the tool into the seam and prying up the red casing as you move along the edges.
    • Make sure to separate all the corners before removing the red casing.
  3. Samsung HMX-W200 Camera Lens Replacement: Schritt 3, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 3, Bild 2 von 2
    • Using the plastic opening tool, separate and pull away the red casing on the right of the LCD screen.
  4. Samsung HMX-W200 Camera Lens Replacement: Schritt 4, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 4, Bild 2 von 2
    • To access the HDMI slot, move slider towards the bottom of the casing on the other side of the camcorder. The lid casing will lift up upon doing so.
    • After accessing the HDMI slot you will find a 5.00mm screw. Using a Phillips #00 screwdriver, remove the screw.
  5. Samsung HMX-W200 Camera Lens Replacement: Schritt 5, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 5, Bild 2 von 2
    • Using the plastic opening tool, separate and pull away the red casing to the left of the LCD screen.
  6. Samsung HMX-W200 Camera Lens Replacement: Schritt 6, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 6, Bild 2 von 2
    • Remove the six 5.00mm screws by using a Phillips #00 screwdriver.
  7. Samsung HMX-W200 Camera Lens Replacement: Schritt 7, Bild 1 von 3 Samsung HMX-W200 Camera Lens Replacement: Schritt 7, Bild 2 von 3 Samsung HMX-W200 Camera Lens Replacement: Schritt 7, Bild 3 von 3
    • Lift the two plastic tabs on the left side of the LCD screen and the single one on the right side on the black casing to open the device.
  8. Samsung HMX-W200 Camera Lens Replacement: Schritt 8, Bild 1 von 1
    • Separate the front and back casing.
  9. Samsung HMX-W200 Camera Lens Replacement, Motherboard: Schritt 9, Bild 1 von 1
    • Once inside the device, find the half that contains the motherboard of the device.
  10. Samsung HMX-W200 Camera Lens Replacement: Schritt 10, Bild 1 von 1
    • Use precision tweezers to gently pull out the USB connection from the motherboard.
  11. Samsung HMX-W200 Camera Lens Replacement: Schritt 11, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 11, Bild 2 von 2
    • Remove the audio connector from the motherboard (red and black cables).
    • Using the plastic opening tool, lift the connectors from all sides before pulling it with your fingers.
    • Do not pull off the connectors by the cables. This could damage the connection from the speaker to the motherboard.
  12. Samsung HMX-W200 Camera Lens Replacement: Schritt 12, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 12, Bild 2 von 2
    • Use precision tweezers to remove the connector joining the LCD and the motherboard.
  13. Samsung HMX-W200 Camera Lens Replacement: Schritt 13, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 13, Bild 2 von 2
    • Remove the six 2.00mm screws with Phillips #00 screwdriver.
  14. Samsung HMX-W200 Camera Lens Replacement: Schritt 14, Bild 1 von 3 Samsung HMX-W200 Camera Lens Replacement: Schritt 14, Bild 2 von 3 Samsung HMX-W200 Camera Lens Replacement: Schritt 14, Bild 3 von 3
    • Lift motherboard from top left side and pull away gently.
  15. Samsung HMX-W200 Camera Lens Replacement, Camera Lens: Schritt 15, Bild 1 von 1
    • Use the precision tweezers, to gently pull and remove the connector connecting lens and motherboard.
  16. Samsung HMX-W200 Camera Lens Replacement: Schritt 16, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 16, Bild 2 von 2
    • Using the precision tweezers, lift silver heat sync tape from motherboard.
  17. Samsung HMX-W200 Camera Lens Replacement: Schritt 17, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 17, Bild 2 von 2
    • Turn the motherboard over.
    • Use Phillips #00 screwdriver to unscrew four 4mm screws holding the camera lens to the motherboard.
  18. Samsung HMX-W200 Camera Lens Replacement: Schritt 18, Bild 1 von 2 Samsung HMX-W200 Camera Lens Replacement: Schritt 18, Bild 2 von 2
    • Gently grab the lens with your fingers and pull it away from the motherboard.
    • Camera lens should easily come off the motherboard when the last screw is loose.
Abschluss
Haya Barakat
521 Reputation
5 Anleitungen geschrieben
USF Tampa, Team 3-6, Sullivan Fall 2016 Mitglied von USF Tampa, Team 3-6, Sullivan Fall 2016
USFT-SULLIVAN-F16S3G6
4 Mitglieder
13 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 7
Letzte 30 Tage: 7
Insgesamt: 194
