Einleitung
Shows how to replace the lens through pictures and words. The lens is located on the motherboard and requires tweezers to unplug ribbons and the remove motherboard from the rear case.
Was du brauchst
To remove the wristband of the device, grab the middle loop and pull the band through.
Open the HDMI door on the side of the camera.
Remove the single screw using a Phillips #00 screwdriver.
Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
Shows front of motherboard and rear of motherboard.
Lens has 4 Phillips size 00 screws.
Remove all 4 PH(00) screws, this will loosen the lens from the motherboard.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
