Einleitung
Demonstrates how to replace the rear case of the camera through instructive pictures and words. Replacement of rear case requires the removal of the motherboard and LCD screen.
Was du brauchst
To remove the wristband of the device, grab the middle loop and pull the band through.
Open the HDMI door on the side of the camera.
Remove the single screw using a Phillips #00 screwdriver.
Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
Use tweezers to grab the wire ribbon, then pull the wire out of connection.
There are 5 Phillips size 00 screws. Remove all 5 screws.
Wire ribbon is attached to the motherboard.
Use tweezers to disconnect the wire as shown. This will loosen the motherboard from the rear case.
Grab the end of the screen, then pull towards the inside of the case. This is a bit tricky. This will release tabs at the top of the screen to the rear case.
