Einleitung
To replace USB port, remove battery first and then remove the USB port while connected to a wire.
  1. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture. To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
    • To remove the wristband of the device, grab the middle loop and pull. Pull the band through as shown in the picture.
  2. Remove all four Hex screws with a Hex 1.5 mm screwdriver. Remove all four Hex screws with a Hex 1.5 mm screwdriver.
    • Remove all four Hex screws with a Hex 1.5 mm screwdriver.
  3. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00. To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
    • To remove the HDMI screw, open the HDMI door on the side. Remove the screw using a Phillip size 00.
  4. As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts. Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case. Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
    • As shown in the picture, use the plastic opening tool on both sides on the device. Pry apart both parts.
    • Do not pry apart the device too hard. There is a wire that attaches the front case with the rear case.
  5. Kostenloser Versand für alle Bestellungen über 100 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
  6. Pull the wire ribbon out with a pair of tweezers. Pull the wire ribbon out with a pair of tweezers. Pull the wire ribbon out with a pair of tweezers.
    • Pull the wire ribbon out with a pair of tweezers.
  7. To remove the battery housing, you must first use a Phillips size 00 to remove the 4 screws. To remove the battery housing, you must first use a Phillips size 00 to remove the 4 screws.
    • To remove the battery housing, you must first use a Phillips size 00 to remove the 4 screws.
  8. Use the plastic opening tool to pry the battery housing open.
    • Use the plastic opening tool to pry the battery housing open.
  9. After removing the battery housing, take the battery out. After removing the battery housing, take the battery out. After removing the battery housing, take the battery out.
    • After removing the battery housing, take the battery out.
  10. Here highlighted are the two Phillips size 00 and the slots where the wire is held. Here highlighted are the two Phillips size 00 and the slots where the wire is held. Here highlighted are the two Phillips size 00 and the slots where the wire is held.
    • Here highlighted are the two Phillips size 00 and the slots where the wire is held.
  11. Use plastic opening tool to pry the plastic cover as shown Use tweezers to remove the wire out of slots. Use tweezers to remove the wire out of slots.
    • Use plastic opening tool to pry the plastic cover as shown
    • Use tweezers to remove the wire out of slots.
  12. Remove both Phillips size 00 on USB port.
    • Remove both Phillips size 00 on USB port.
  13. Now push USB port inside the case to remove as shown. Now push USB port inside the case to remove as shown.
    • Now push USB port inside the case to remove as shown.
Abschluss
Robert
909 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 9-2, Blackwell Winter 2015 Mitglied von USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Mitglieder
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 3
Insgesamt: 268
