Einleitung
To replace USB port, remove battery first and then remove the USB port while connected to a wire.
Was du brauchst
To remove the wristband of the device, grab the middle loop and pull the band through.
Open the HDMI door on the side of the camera.
Remove the single screw using a Phillips #00 screwdriver.
Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
Remove the four screws from the battery housing using a Phillips #00 screwdriver.
Use an iFixit opening tool to pry up the plastic cover.
Use tweezers to remove the wire from the slots.
