Zum Hauptinhalt wechseln
Samsung HMX-W300 USB Port Replacement
Was du brauchst
  1. Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: Schritt 1, Bild 1 von 3 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: Schritt 1, Bild 2 von 3 Samsung HMX-W300 USB Port Replacement, Disassembling Samsung HMX-W300: Schritt 1, Bild 3 von 3
    • To remove the wristband of the device, grab the middle loop and pull the band through.
  2. Samsung HMX-W300 USB Port Replacement: Schritt 2, Bild 1 von 2 Samsung HMX-W300 USB Port Replacement: Schritt 2, Bild 2 von 2
    • Remove four screws with a Hex 1.5 mm screwdriver.
  3. Samsung HMX-W300 USB Port Replacement: Schritt 3, Bild 1 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 3, Bild 2 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 3, Bild 3 von 3
    • Open the HDMI door on the side of the camera.
    • Remove the single screw using a Phillips #00 screwdriver.
  4. Samsung HMX-W300 USB Port Replacement: Schritt 4, Bild 1 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 4, Bild 2 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 4, Bild 3 von 3
    • Use the iFixit opening tool on both sides on the device. Pry apart both sections with light force.
    • Do not apply too much force. There is a wire that attaches the front case with the rear case that can be damaged.
  5. Samsung HMX-W300 USB Port Replacement: Schritt 5, Bild 1 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 5, Bild 2 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 5, Bild 3 von 3
    • Pull the wire ribbon out with a pair of tweezers.
  6. Samsung HMX-W300 USB Port Replacement, Battery: Schritt 6, Bild 1 von 2 Samsung HMX-W300 USB Port Replacement, Battery: Schritt 6, Bild 2 von 2
    • Remove the four screws from the battery housing using a Phillips #00 screwdriver.
  7. Samsung HMX-W300 USB Port Replacement: Schritt 7, Bild 1 von 1
    • Use the iFixit opening tool to pry the battery housing open.
  8. Samsung HMX-W300 USB Port Replacement: Schritt 8, Bild 1 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 8, Bild 2 von 3 Samsung HMX-W300 USB Port Replacement: Schritt 8, Bild 3 von 3
    • After removing the battery housing, take the battery out.
  9. Samsung HMX-W300 USB Port Replacement, USB Port: Schritt 9, Bild 1 von 3 Samsung HMX-W300 USB Port Replacement, USB Port: Schritt 9, Bild 2 von 3 Samsung HMX-W300 USB Port Replacement, USB Port: Schritt 9, Bild 3 von 3
    • Use an iFixit opening tool to pry up the plastic cover.
    • Use tweezers to remove the wire from the slots.
  10. Samsung HMX-W300 USB Port Replacement: Schritt 10, Bild 1 von 2 Samsung HMX-W300 USB Port Replacement: Schritt 10, Bild 2 von 2
    • Remove both screws from the USB port using a Phillips #00 screwdriver.
  11. Samsung HMX-W300 USB Port Replacement: Schritt 11, Bild 1 von 2 Samsung HMX-W300 USB Port Replacement: Schritt 11, Bild 2 von 2
    • Push the USB port inside the case to remove it from the device.
Abschluss
Robert
966 Reputation
8 Anleitungen geschrieben
USF Tampa, Team 9-2, Blackwell Winter 2015 Mitglied von USF Tampa, Team 9-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S9G2
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 9
Letzte 30 Tage: 14
Insgesamt: 430
