Zum Hauptinhalt wechseln
Einleitung
How to remove & replace the phone's back cover.
Ersatzteile
Keine Ersatzteile angegeben.
  1. Orient the phone with the screen facing down.
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Grip the battery on its sides, opposite the direction of the white arrow. Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
    • Grip the battery on its sides, opposite the direction of the white arrow.
    • Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
  3. Remove the six 3.5 mm screws using a Phillips #000 screwdriver.
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver.
  4. Remove the back cover by gently prying around the top and bottom edges with a nylon spudger.
    • Remove the back cover by gently prying around the top and bottom edges with a nylon spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and are prone to falling out, so put these in a safe place.
Abschluss
Saul Villatoro
255 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 8-10, Regan Spring 2011 Mitglied von Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzten 24 Stunden: 0
Letzten 7 Tage: 0
Letzten 30 Tage: 0
Insgesamt: 1,645
