Einleitung
How to remove & replace the phone's back speaker.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Grip the battery on its sides, opposite the direction of the white arrow.
Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
Remove the six 3.5 mm Phillips #000 screws, using a Phillips #000 screwdriver.
Remove the back cover by gently prying around the top and bottom edges with a nylon spudger.
The side buttons will become loose and are prone to falling out, so put these in a safe place.
Remove the back speaker by carefully lifting it up.
The speaker will still be attached to the circuit board by a wire and a small piece of clear plastic.
Disconnect the speaker by lifting the clear plastic piece at the end of the wire.
3 weitere Nutzer haben diese Anleitung absolviert.
