Zum Hauptinhalt wechseln
Samsung Impression Circuit Board Replacement
Was du brauchst
  1. Samsung Impression Circuit Board Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the phone with the screen facing downward.
    • Slide the panel away from the camera using your thumb. This will expose the battery.
  2. Samsung Impression Circuit Board Replacement: Schritt 2, Bild 1 von 2 Samsung Impression Circuit Board Replacement: Schritt 2, Bild 2 von 2
    • Insert the tip of the spudger on the left side of the battery.
    • Pry the battery out. It will pivot in the direction of the white arrow.
  3. Samsung Impression Circuit Board Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
  4. Samsung Impression Circuit Board Replacement: Schritt 4, Bild 1 von 1
    • Gently pry around the edges with the spudger to remove back panel.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Circuit Board Replacement, Back Speaker: Schritt 5, Bild 1 von 1
    • Carefully pry the back speaker upwards with a spudger.
    • The speaker is still connected to the circuit board by a wire and small piece of clear plastic.
    • Disconnect the speaker by lifting the clear plastic piece attached to the wire.
  6. Samsung Impression Circuit Board Replacement, Circuit Board: Schritt 6, Bild 1 von 1
    • Gently remove the black wire to free the circuit board.
    • Remove the wire by gently prying up the gold terminator attached to the green circuit board.
  7. Samsung Impression Circuit Board Replacement: Schritt 7, Bild 1 von 2 Samsung Impression Circuit Board Replacement: Schritt 7, Bild 2 von 2
    • Gently tug the black and blue ribbon upwards to release the circuit board.
Abschluss
To reassemble the device, carefully follow these instructions in reverse order. With a new circuit board installed, your phone should be functional again! For more guides on Samsung Impression maintenance, visit www.ifixit.com.
Ross McKelvie
196 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 8-10, Regan Spring 2011 Mitglied von Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 3,858
