Zum Hauptinhalt wechseln
Samsung Impression Digitizer or Front Buttons Replacement
Was du brauchst
  1. Samsung Impression Digitizer or Front Buttons Replacement, Battery: Schritt 1, Bild 1 von 1
    • Orient the phone with the screen facing down.
    • Using your thumb, slide the back panel away from the camera to expose the battery.
  2. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 2, Bild 1 von 2 Samsung Impression Digitizer or Front Buttons Replacement: Schritt 2, Bild 2 von 2
    • Insert the tip of the spudger on the left side of the battery, opposite the direction of the white arrow.
    • Pry the battery free. It will pivot in the direction of the white arrow.
  3. Samsung Impression Digitizer or Front Buttons Replacement, Back Cover: Schritt 3, Bild 1 von 1
    • Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Make sure to unscrew in a counterclockwise direction.
  4. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 4, Bild 1 von 1
    • Remove the back cover by gently prying around the top and bottom edges with the spudger.
    • It may help to slide the touchscreen upwards when removing the back panel.
    • The side buttons will become loose and will fall out, so put these in a safe place.
  5. Samsung Impression Digitizer or Front Buttons Replacement, Circuit Board: Schritt 5, Bild 1 von 1
    • To free the circuit board, remove the black wire that is holding it down.
    • You can remove the wire by gently prying up the gold terminator that is attached to the green circuit board. A gentle tug is all it should take.
  6. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 6, Bild 1 von 2 Samsung Impression Digitizer or Front Buttons Replacement: Schritt 6, Bild 2 von 2
    • The circuit board will still be held on by a blue and black ribbon. Remove the entire circuit board by gently tugging the ribbon upwards.
  7. Samsung Impression Digitizer or Front Buttons Replacement, Keyboard: Schritt 7, Bild 1 von 1
    • Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
    • The screws are 2.7mm in length.
    • The bottom black end cap will snap out.
  8. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 8, Bild 1 von 2 Samsung Impression Digitizer or Front Buttons Replacement: Schritt 8, Bild 2 von 2
    • Remove 6 screws holding the silver plate on.
    • 2.7mm in length
    • The keys will peel right out of the screen side of the phone.
  9. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 9, Bild 1 von 1
    • The silver piece you are left with is the physical keyboard assembly.
  10. Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: Schritt 10, Bild 1 von 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD Flex Cable: Schritt 10, Bild 2 von 2
    • Remove the 3 screws holding down the flex cable.
    • The screws are 2.0 mm in length.
    • The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
    • The keyboard slider frame will come off and the flex cable exposed, but not free.
  11. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 11, Bild 1 von 1
    • Remove 4 outer screws.
    • The screws are 3.5mm in length.
  12. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 12, Bild 1 von 3 Samsung Impression Digitizer or Front Buttons Replacement: Schritt 12, Bild 2 von 3 Samsung Impression Digitizer or Front Buttons Replacement: Schritt 12, Bild 3 von 3
    • Slide the phone apart, and remove a 5th screw (3.5 mm).
    • Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
    • The device will now be in two pieces
  13. Samsung Impression Digitizer or Front Buttons Replacement: Schritt 13, Bild 1 von 2 Samsung Impression Digitizer or Front Buttons Replacement: Schritt 13, Bild 2 von 2
    • Lift the tab underneath the blue tape and gently pull the flex cable.
    • The flex cable will now be completely free.
  14. Samsung Impression Digitizer or Front Buttons Replacement, Ear Speaker: Schritt 14, Bild 1 von 1
    • Remove the single screw.
    • This screw is 2.25 mm in length.
    • Lift the black tab at the end of the ribbon.
    • Gently pull the speaker and ribbon free.
  15. Samsung Impression Digitizer or Front Buttons Replacement, LCD: Schritt 15, Bild 1 von 2 Samsung Impression Digitizer or Front Buttons Replacement, LCD: Schritt 15, Bild 2 von 2
    • Lift the remaining two tabs and free their respective ribbon cables.
    • Gently pry the screen away from the housing.
    • Be careful with this step as you are in direct contact with the LCD screen.
  16. Samsung Impression Digitizer or Front Buttons Replacement, Digitizer or Front Buttons: Schritt 16, Bild 1 von 1
    • If replacing the front buttons, remove the assembly at the bottom of the front panel
    • The digitizer is now free to be pulled out from the front housing.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Saul Villatoro
255 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 8-10, Regan Spring 2011 Mitglied von Cal Poly, Team 8-10, Regan Spring 2011
CPSU-REGAN-S11S8G10
4 Mitglieder
22 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 6,820
