Einleitung
How to remove & replace the phone's ear speaker.
Werkzeuge
Ersatzteile
Keine Ersatzteile angegeben.
Orient the phone with the screen facing down.
Using your thumb, slide the back panel away from the camera to expose the battery.
Grip the battery on its sides, opposite the direction of the white arrow.
Pry the battery up. It will pivot at the end with the white arrow. The battery will now be free.
Snap off back the cover by gently prying around the top and bottom edges with a flat head screwdriver.
The side buttons will become loose and are prone to fall out, so put these in a safe place.
To free the circuit board, remove the black wire that is holding it down.
The circuit board will still be held on by a blue and black ribbon that is removed by gently pulling it upwards.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
Remove 6 screws holding the silver plate on.
2.7mm in length
The keys will peel right out of the screen side of the phone.
Remove the 3 screws holding down the flex cable.
The screws are 2.0 mm in length.
The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
The keyboard slider frame will come off and the flex cable exposed, but not free.
Slide the phone apart, and remove a 5th screw (3.5 mm).
Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
The device will now be in two pieces
Lift the tab underneath the blue tape and gently pull the flex cable.
The flex cable will now be completely free.
Remove the single screw.
This screw is 2.25 mm in length.
Lift the black tab at the end of the ribbon.
Gently pull the speaker and ribbon free.
