Einleitung
How to remove & replace the phone's LCD flex cable.
Was du brauchst
Orient the phone with the screen facing downward.
Slide the panel away from the camera using your thumb. This will expose the battery.
Insert the tip of the spudger on the left side of the battery.
Pry the battery out. It will pivot in the direction of the white arrow.
Remove the six 3.5 mm screws using a Phillips #000 screwdriver. Unscrew in a counterclockwise direction.
Gently pry around the edges with the spudger to remove back panel.
The side buttons will become loose and will fall out, so put these in a safe place.
Remove the two base screws along the edge of the silver piece, where you just removed the black end piece.
The screws are 2.7mm in length.
The bottom black end cap will snap out.
Remove 6 screws holding the silver plate on.
2.7mm in length
The keys will peel right out of the screen side of the phone.
Remove the 3 screws holding down the flex cable.
The screws are 2.0 mm in length.
The screw that goes through the circle port on the flex cable is longer at 2.3mm long.
The keyboard slider frame will come off and the flex cable exposed, but not free.
Slide the phone apart, and remove a 5th screw (3.5 mm).
Remove the outer shell by prying the edges off with your fingers, or a small screwdriver. (second image, taken before the image for above instruction)
The device will now be in two pieces
Lift the tab underneath the blue tape and gently pull the flex cable.
The flex cable will now be completely free.
2 weitere Personen haben diese Anleitung absolviert.
