Einleitung
This guide shows how to take out the antenna so that a replacement can be installed.
Was du brauchst
Apply pressure to the back cover and slide it forward towards the camera.
Lift the back cover off the phone.
Use the plastic opening tool to unhinge the locks around the edges of the phone.
Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
