Zum Hauptinhalt wechseln
Samsung Instinct Antenna Replacement
Was du brauchst
  1. Samsung Instinct Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Antenna Replacement: Schritt 2, Bild 1 von 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Antenna Replacement, Back Case: Schritt 3, Bild 1 von 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Antenna Replacement: Schritt 4, Bild 1 von 2 Samsung Instinct Antenna Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Antenna Replacement: Schritt 5, Bild 1 von 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Antenna Replacement, Antenna: Schritt 6, Bild 1 von 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Antenna Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Antenna Replacement: Schritt 8, Bild 1 von 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Antenna Replacement: Schritt 9, Bild 1 von 1
    • Gently lift up on the antenna and remove it from the back of the device.
Abschluss
Jimmy Kuo
14 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-13, Regan Fall 2011 Mitglied von Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 7
Insgesamt: 1,072
