Was du brauchst
Apply pressure to the back cover and slide it forward towards the camera.
Lift the back cover off the phone.
Use the plastic opening tool to unhinge the locks around the edges of the phone.
Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
Remove the two 3.50mm screws connecting the motherboard to the case.
Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
Once the motherboard is removed from the frame, use the pry tool to remove the camera.
Insert the pry bar between the camera and the frame then lift up.
The camera is held in by adhesive so it will require some force to remove.
You have now successfully removed the camera from your Samsung Instinct.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
