Was du brauchst
Apply pressure to the back cover and slide it forward towards the camera.
Lift the back cover off the phone.
Use the plastic opening tool to unhinge the locks around the edges of the phone.
Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
Remove the two 3.50mm screws connecting the motherboard to the case.
Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
Using the plastic opener tool, detach the ribbon located on the bottom of the phone below the battery compartment.
Lift the microchip (located at the bottom of the phone) and insert the plastic opener tool under the screen.
Lift up the screen. The microchip is attached to the screen and will be lifted out with the screen.
After lifting out the LCD screen, the screen and its housing should be separated as shown.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
