Zum Hauptinhalt wechseln
Samsung Instinct Motherboard Replacement
Was du brauchst
  1. Samsung Instinct Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Apply pressure to the back cover and slide it forward towards the camera.
    • Lift the back cover off the phone.
  2. Samsung Instinct Motherboard Replacement: Schritt 2, Bild 1 von 1
    • Holding the phone firmly, use the notches to grip and lift up the battery.
  3. Samsung Instinct Motherboard Replacement, Back Case: Schritt 3, Bild 1 von 1
    • Remove the four 4.45mm screws at the corners of the phone.
  4. Samsung Instinct Motherboard Replacement: Schritt 4, Bild 1 von 2 Samsung Instinct Motherboard Replacement: Schritt 4, Bild 2 von 2
    • Use the plastic opening tool to unhinge the locks around the edges of the phone.
    • Do not worry about the inner components of the phone; they are not connected to this case.
  5. Samsung Instinct Motherboard Replacement: Schritt 5, Bild 1 von 1
    • Lift the casing off of the phone.
  6. Samsung Instinct Motherboard Replacement, Antenna: Schritt 6, Bild 1 von 1
    • With the screws removed, locate the antenna.
  7. Samsung Instinct Motherboard Replacement: Schritt 7, Bild 1 von 1
    • Using a Phillips head screwdriver, remove the 4.50mm screw holding the antenna in place.
  8. Samsung Instinct Motherboard Replacement: Schritt 8, Bild 1 von 1
    • Using the plastic opener tool, squeeze gently on the antenna cable connector and lift to remove the connector from its position.
  9. Samsung Instinct Motherboard Replacement: Schritt 9, Bild 1 von 1
    • Gently lift up on the antenna and remove it from the back of the device.
  10. Samsung Instinct Motherboard Replacement, Front Case: Schritt 10, Bild 1 von 1
    • Remove the two 3.50mm screws connecting the motherboard to the case.
  11. Samsung Instinct Motherboard Replacement: Schritt 11, Bild 1 von 3 Samsung Instinct Motherboard Replacement: Schritt 11, Bild 2 von 3 Samsung Instinct Motherboard Replacement: Schritt 11, Bild 3 von 3
    • Use the plastic opener tool to detach the three ribbons on the motherboard.
  12. Samsung Instinct Motherboard Replacement: Schritt 12, Bild 1 von 1
    • Lift out the top right ribbon from its slot on the motherboard.
  13. Samsung Instinct Motherboard Replacement: Schritt 13, Bild 1 von 2 Samsung Instinct Motherboard Replacement: Schritt 13, Bild 2 von 2
    • Use the plastic opener tool to unhinge the the locks on the side of the motherboard connecting it to the front casing.
  14. Samsung Instinct Motherboard Replacement: Schritt 14, Bild 1 von 1
    • Lift the motherboard away from the front casing.
  15. Samsung Instinct Motherboard Replacement: Schritt 15, Bild 1 von 1
    • After removing lifting up on the motherboard, the front casing and center frame should be separated as shown.
  16. Samsung Instinct Motherboard Replacement, Motherboard: Schritt 16, Bild 1 von 3 Samsung Instinct Motherboard Replacement, Motherboard: Schritt 16, Bild 2 von 3 Samsung Instinct Motherboard Replacement, Motherboard: Schritt 16, Bild 3 von 3
    • Using the plastic opener tool, gently pry away the side strip control buttons from the metal center frame.
    • There are three strips total: one on the right, left, and top of the phone.
  17. Samsung Instinct Motherboard Replacement: Schritt 17, Bild 1 von 1
    • Using the plastic opener tool, pry the speaker connector away from the back of the motherboard.
  18. Samsung Instinct Motherboard Replacement: Schritt 18, Bild 1 von 1
    • Using the plastic opener tool, remove the speaker from its setting.
    • Pry where the wire enters the speaker.
    • The speaker has adhesive on the bottom, thus removing it will require a bit of wiggling.
  19. Samsung Instinct Motherboard Replacement: Schritt 19, Bild 1 von 1
    • Gently lift the motherboard from the center frame.
Abschluss
Brayton
49 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 3-13, Regan Fall 2011 Mitglied von Cal Poly, Team 3-13, Regan Fall 2011
CPSU-REGAN-F11S3G13
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 5,068
