Zum Hauptinhalt wechseln
Samsung Jack Antenna Replacement
Was du brauchst
  1. Samsung Jack Antenna Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Antenna Replacement: Schritt 2, Bild 1 von 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Antenna Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Antenna Replacement: Schritt 4, Bild 1 von 3 Samsung Jack Antenna Replacement: Schritt 4, Bild 2 von 3 Samsung Jack Antenna Replacement: Schritt 4, Bild 3 von 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Antenna Replacement: Schritt 5, Bild 1 von 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Antenna Replacement, Antenna: Schritt 6, Bild 1 von 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Samsung Jack Antenna Replacement: Schritt 7, Bild 1 von 3 Samsung Jack Antenna Replacement: Schritt 7, Bild 2 von 3 Samsung Jack Antenna Replacement: Schritt 7, Bild 3 von 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
Abschluss
Paul Piller
56 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 24-57, Amido Spring 2011 Mitglied von Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 2,331
