Zum Hauptinhalt wechseln
Samsung Jack LCD Replacement
Was du brauchst
  1. Samsung Jack LCD Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack LCD Replacement: Schritt 2, Bild 1 von 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack LCD Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack LCD Replacement: Schritt 4, Bild 1 von 3 Samsung Jack LCD Replacement: Schritt 4, Bild 2 von 3 Samsung Jack LCD Replacement: Schritt 4, Bild 3 von 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack LCD Replacement: Schritt 5, Bild 1 von 1
    • Lift the rear case off of the phone.
  6. Samsung Jack LCD Replacement, Antenna: Schritt 6, Bild 1 von 1
    • Remove the two silver 4.30 mm screws on either side of the antenna using a Phillip's #00 Screwdriver.
  7. Samsung Jack LCD Replacement: Schritt 7, Bild 1 von 3 Samsung Jack LCD Replacement: Schritt 7, Bild 2 von 3 Samsung Jack LCD Replacement: Schritt 7, Bild 3 von 3
    • There is a wire under the antenna connecting it to the Motherboard. Do not pull off the antenna just yet.
    • Use a spudger to remove the wire connector under the antenna.
  8. Samsung Jack LCD Replacement, Speaker: Schritt 8, Bild 1 von 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  9. Samsung Jack LCD Replacement: Schritt 9, Bild 1 von 2 Samsung Jack LCD Replacement: Schritt 9, Bild 2 von 2
    • Use the spudger to detach the speaker ribbon cable.
  10. Samsung Jack LCD Replacement: Schritt 10, Bild 1 von 1
    • Lift the speaker out of its compartment.
  11. Samsung Jack LCD Replacement, Motherboard: Schritt 11, Bild 1 von 1
    • Remove the power and volume buttons on the right side of the Motherboard.
  12. Samsung Jack LCD Replacement: Schritt 12, Bild 1 von 2 Samsung Jack LCD Replacement: Schritt 12, Bild 2 von 2
    • Use a spudger to detach the camera ribbon cable.
    • Lift the camera off of the Motherboard.
  13. Samsung Jack LCD Replacement: Schritt 13, Bild 1 von 2 Samsung Jack LCD Replacement: Schritt 13, Bild 2 von 2
    • Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
  14. Samsung Jack LCD Replacement: Schritt 14, Bild 1 von 3 Samsung Jack LCD Replacement: Schritt 14, Bild 2 von 3 Samsung Jack LCD Replacement: Schritt 14, Bild 3 von 3
    • Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
    • Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
  15. Samsung Jack LCD Replacement: Schritt 15, Bild 1 von 2 Samsung Jack LCD Replacement: Schritt 15, Bild 2 von 2
    • There is a ribbon cable under the Motherboard connecting it to the LCD. Do not pull off the Motherboard just yet.
    • Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
    • Use a spudger to disconnect the Motherboard ribbon cable.
  16. Samsung Jack LCD Replacement: Schritt 16, Bild 1 von 1
    • Lift the Motherboard off of the phone.
  17. Samsung Jack LCD Replacement, LCD: Schritt 17, Bild 1 von 3 Samsung Jack LCD Replacement, LCD: Schritt 17, Bild 2 von 3 Samsung Jack LCD Replacement, LCD: Schritt 17, Bild 3 von 3
    • The LCD frame is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool between the LCD frame and the front case of the phone.
    • Slide the Plastic Opening Tool around the LCD frame to detach all of the clips.
  18. Samsung Jack LCD Replacement: Schritt 18, Bild 1 von 2 Samsung Jack LCD Replacement: Schritt 18, Bild 2 von 2
    • Lift up the LCD frame.
  19. Samsung Jack LCD Replacement: Schritt 19, Bild 1 von 3 Samsung Jack LCD Replacement: Schritt 19, Bild 2 von 3 Samsung Jack LCD Replacement: Schritt 19, Bild 3 von 3
    • There is a hanging ribbon cable connected to the LCD screen that passes through the LCD frame.
    • Insert the spudger under the bottom left corner of the LCD screen.
    • Use the spudger to gently pry the LCD screen out of its frame.
    • Gently remove the screen from the frame.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Paul Piller
56 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 24-57, Amido Spring 2011 Mitglied von Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 1
Insgesamt: 1,901
