Einleitung
Use this repair guide to replace the Motherboard.
Was du brauchst
Slide the battery cover downwards with pressure focused on the center of the cover.
Lift the cover off of the phone.
Grasp the bottom left and right corners of the battery and lift it from its housing.
Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
Insert the Plastic Opening Tool in between the front and rear cases.
Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
Remove the power and volume buttons on the right side of the Motherboard.
Use a spudger to detach the camera ribbon cable.
Lift the camera off of the Motherboard.
Use a spudger to disconnect the white antenna wire on the bottom right corner of the Motherboard.
Use a Plastic Opening Tool to lift the flaps of the ZIF connectors to release the ribbon cables near the bottom of the Motherboard.
Use a spudger to carefully pull the ribbon cables away from the ZIF connectors.
Insert the Plastic Opening Tool under the upper left corner of the Motherboard to help reveal the ribbon cable.
Use a spudger to disconnect the Motherboard ribbon cable.
