Einleitung
Use this guide to replace the speaker.
Ersatzteile
Kein Ersatzteil erforderlich.
  1. Slide the battery cover downwards with pressure focused on the center of the cover.
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Grasp the bottom left and right corners of the battery and lift it from its housing.
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Kostenloser Versand für alle Bestellungen über 100,00 $ oder mit einem Pro Tech Toolkit!
    Schau dich im Store um
    Ever fixed something? That’s Genius.
    Share your repair story with #ImAGenius
    We Are All Geniuses
  5. The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force. Insert the Plastic Opening Tool in between the front and rear cases. Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  6. Lift the rear case off of the phone.
    • Lift the rear case off of the phone.
  7. Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  8. Use the spudger to detach the speaker ribbon cable. Use the spudger to detach the speaker ribbon cable.
    • Use the spudger to detach the speaker ribbon cable.
  9. Lift the speaker out of its compartment.
    • Lift the speaker out of its compartment.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Paul Piller
56 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 24-57, Amido Spring 2011 Mitglied von Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Mitglieder
7 Anleitungen geschrieben
Statistik anzeigen:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,632
