Zum Hauptinhalt wechseln
Samsung Jack Speaker Replacement
Was du brauchst
  1. Samsung Jack Speaker Replacement, Battery: Schritt 1, Bild 1 von 1
    • Slide the battery cover downwards with pressure focused on the center of the cover.
    • Lift the cover off of the phone.
  2. Samsung Jack Speaker Replacement: Schritt 2, Bild 1 von 1
    • Grasp the bottom left and right corners of the battery and lift it from its housing.
  3. Samsung Jack Speaker Replacement, Rear Case: Schritt 3, Bild 1 von 1
    • Remove the four black 7.30 mm screws surrounding the battery housing using a Phillips #00 Screwdriver.
  4. Samsung Jack Speaker Replacement: Schritt 4, Bild 1 von 3 Samsung Jack Speaker Replacement: Schritt 4, Bild 2 von 3 Samsung Jack Speaker Replacement: Schritt 4, Bild 3 von 3
    • The rear case is firmly attached to the phone with clips. Do not be afraid to use a little extra force.
    • Insert the Plastic Opening Tool in between the front and rear cases.
    • Pry with the Plastic Opening Tool around all edges of the phone until you free all the clips.
  5. Samsung Jack Speaker Replacement: Schritt 5, Bild 1 von 1
    • Lift the rear case off of the phone.
  6. Samsung Jack Speaker Replacement, Speaker: Schritt 6, Bild 1 von 1
    • Remove the two black 7.30 mm screws on the top right and left corners of the Motherboard using a Phillips #00 Screwdriver.
    • Remove the silver 4.50 mm screw located below the speaker using a Phillips #00 Screwdriver.
  7. Samsung Jack Speaker Replacement: Schritt 7, Bild 1 von 2 Samsung Jack Speaker Replacement: Schritt 7, Bild 2 von 2
    • Use the spudger to detach the speaker ribbon cable.
  8. Samsung Jack Speaker Replacement: Schritt 8, Bild 1 von 1
    • Lift the speaker out of its compartment.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Paul Piller
56 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 24-57, Amido Spring 2011 Mitglied von Cal Poly, Team 24-57, Amido Spring 2011
CPSU-AMIDO-S11S24G57
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 0
Insgesamt: 1,726
