Zum Hauptinhalt wechseln
Samsung Juke Click Wheel Replacement
Was du brauchst
  1. Samsung Juke Click Wheel Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Click Wheel Replacement: Schritt 2, Bild 1 von 2 Samsung Juke Click Wheel Replacement: Schritt 2, Bild 2 von 2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Click Wheel Replacement, Camera/Speaker: Schritt 3, Bild 1 von 1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Click Wheel Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Click Wheel Replacement: Schritt 5, Bild 1 von 3 Samsung Juke Click Wheel Replacement: Schritt 5, Bild 2 von 3 Samsung Juke Click Wheel Replacement: Schritt 5, Bild 3 von 3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Click Wheel Replacement: Schritt 6, Bild 1 von 1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Click Wheel Replacement: Schritt 7, Bild 1 von 2 Samsung Juke Click Wheel Replacement: Schritt 7, Bild 2 von 2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Click Wheel Replacement: Schritt 8, Bild 1 von 2 Samsung Juke Click Wheel Replacement: Schritt 8, Bild 2 von 2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke Click Wheel Replacement, Motherboard: Schritt 9, Bild 1 von 2 Samsung Juke Click Wheel Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke Click Wheel Replacement: Schritt 10, Bild 1 von 2 Samsung Juke Click Wheel Replacement: Schritt 10, Bild 2 von 2
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke Click Wheel Replacement: Schritt 11, Bild 1 von 3 Samsung Juke Click Wheel Replacement: Schritt 11, Bild 2 von 3 Samsung Juke Click Wheel Replacement: Schritt 11, Bild 3 von 3
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
  12. Samsung Juke Click Wheel Replacement, Keyboard: Schritt 12, Bild 1 von 3 Samsung Juke Click Wheel Replacement, Keyboard: Schritt 12, Bild 2 von 3 Samsung Juke Click Wheel Replacement, Keyboard: Schritt 12, Bild 3 von 3
    • Open/swivel the phone so the back of the LCD panel is visible.
    • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
    • A moderate amount of force may need to be applied.
  13. Samsung Juke Click Wheel Replacement, Click Wheel: Schritt 13, Bild 1 von 2 Samsung Juke Click Wheel Replacement, Click Wheel: Schritt 13, Bild 2 von 2
    • Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
    • Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
  14. Samsung Juke Click Wheel Replacement: Schritt 14, Bild 1 von 3 Samsung Juke Click Wheel Replacement: Schritt 14, Bild 2 von 3 Samsung Juke Click Wheel Replacement: Schritt 14, Bild 3 von 3
    • Using a generous amount of force, use your hands to pry loose the casing from the LCD panel.
    • If necessary, use the iFixit opening tool to completely free the casing.
    • Be careful not to sever the wire connecting the outer casing to the display board.
  15. Samsung Juke Click Wheel Replacement: Schritt 15, Bild 1 von 3 Samsung Juke Click Wheel Replacement: Schritt 15, Bild 2 von 3 Samsung Juke Click Wheel Replacement: Schritt 15, Bild 3 von 3
    • Using the iFixit opening tool, remove the click wheel from the board.
    • After you have freed the edges, use the spudger to release the clip holding it flush to the board.
  16. Samsung Juke Click Wheel Replacement: Schritt 16, Bild 1 von 3 Samsung Juke Click Wheel Replacement: Schritt 16, Bild 2 von 3 Samsung Juke Click Wheel Replacement: Schritt 16, Bild 3 von 3
    • Unlock the ribbon connection by pressing down on the black clip.
    • Carefully pull the click wheel away from the device.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ryan Turner
104 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-18, Maness Spring 2010 Mitglied von Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Mitglieder
12 Anleitungen geschrieben
Ein Kommentar
All I have to say is: THANK YOU!
My juke's click wheel got stuck, which was draining my battery. I followed the incredibly easy to understand instructions and pictures and was able to free my click wheel. I cleaned the wheel and put my phone back together by going backward though the instructions, turned on my phone, and IT WORKED PERFECTLY. This saved my from having to buy a new, large and extremely expensive phone.
Thank You so much for these great, step-by-step instructions!
Rachel Krebs - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 3,380
