Zum Hauptinhalt wechseln
Samsung Juke Motherboard Replacement
Was du brauchst
  1. Samsung Juke Motherboard Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Motherboard Replacement: Schritt 2, Bild 1 von 2 Samsung Juke Motherboard Replacement: Schritt 2, Bild 2 von 2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Motherboard Replacement, Camera/Speaker: Schritt 3, Bild 1 von 1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Motherboard Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Motherboard Replacement: Schritt 5, Bild 1 von 3 Samsung Juke Motherboard Replacement: Schritt 5, Bild 2 von 3 Samsung Juke Motherboard Replacement: Schritt 5, Bild 3 von 3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Motherboard Replacement: Schritt 6, Bild 1 von 1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Motherboard Replacement: Schritt 7, Bild 1 von 2 Samsung Juke Motherboard Replacement: Schritt 7, Bild 2 von 2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Motherboard Replacement: Schritt 8, Bild 1 von 2 Samsung Juke Motherboard Replacement: Schritt 8, Bild 2 von 2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke Motherboard Replacement, Motherboard: Schritt 9, Bild 1 von 2 Samsung Juke Motherboard Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke Motherboard Replacement: Schritt 10, Bild 1 von 2 Samsung Juke Motherboard Replacement: Schritt 10, Bild 2 von 2
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke Motherboard Replacement: Schritt 11, Bild 1 von 3 Samsung Juke Motherboard Replacement: Schritt 11, Bild 2 von 3 Samsung Juke Motherboard Replacement: Schritt 11, Bild 3 von 3
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 6-18, Maness Spring 2010 Mitglied von Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 12
Insgesamt: 2,933
