Zum Hauptinhalt wechseln
Samsung Juke Outer Casing Replacement
Was du brauchst
  1. Samsung Juke Outer Casing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Press and hold down the button on the bottom side of the phone with your finger.
  2. Samsung Juke Outer Casing Replacement: Schritt 2, Bild 1 von 2 Samsung Juke Outer Casing Replacement: Schritt 2, Bild 2 von 2
    • While holding the button down, remove the back cover of the phone.
  3. Samsung Juke Outer Casing Replacement, Camera/Speaker: Schritt 3, Bild 1 von 1
    • Remove the four screws from the back of the phone using a Phillips #00 screwdriver.
  4. Samsung Juke Outer Casing Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 7.3 mm screws from the camera and the speaker at the bottom back plate of the phone using a Phillips #00 screwdriver.
  5. Samsung Juke Outer Casing Replacement: Schritt 5, Bild 1 von 3 Samsung Juke Outer Casing Replacement: Schritt 5, Bild 2 von 3 Samsung Juke Outer Casing Replacement: Schritt 5, Bild 3 von 3
    • Locate the USB port (where the charger can be plugged in). Using the iFixit opening tool, open the phone cover.
    • Failure to open USB port cover at this stage may result in damaging the device.
  6. Samsung Juke Outer Casing Replacement: Schritt 6, Bild 1 von 1
    • Remove the 5.5 mm screws from both sides of the camera/speaker with a Phillips #00 screwdriver.
  7. Samsung Juke Outer Casing Replacement: Schritt 7, Bild 1 von 2 Samsung Juke Outer Casing Replacement: Schritt 7, Bild 2 von 2
    • Use the iFixit opening tool to remove the camera/speaker from the motherboard.
    • Practice caution to prevent damage to the attaching ribbon.
  8. Samsung Juke Outer Casing Replacement: Schritt 8, Bild 1 von 2 Samsung Juke Outer Casing Replacement: Schritt 8, Bild 2 von 2
    • Use the iFixit opening tool to gently pry the camera/speaker off.
  9. Samsung Juke Outer Casing Replacement, Motherboard: Schritt 9, Bild 1 von 2 Samsung Juke Outer Casing Replacement, Motherboard: Schritt 9, Bild 2 von 2
    • Use the iFixit opening tool to remove the yellow tab on the motherboard.
  10. Samsung Juke Outer Casing Replacement: Schritt 10, Bild 1 von 2 Samsung Juke Outer Casing Replacement: Schritt 10, Bild 2 von 2
    • Use the iFixit opening tool to remove the other orange tab to free the motherboard.
  11. Samsung Juke Outer Casing Replacement: Schritt 11, Bild 1 von 3 Samsung Juke Outer Casing Replacement: Schritt 11, Bild 2 von 3 Samsung Juke Outer Casing Replacement: Schritt 11, Bild 3 von 3
    • To completely remove the motherboard, use the iFixit opening tool to leverage it up, then use your fingers to pull it out.
    • Do not be alarmed if the volume and hold buttons are removed from the motherboard.
  12. Samsung Juke Outer Casing Replacement, Keyboard: Schritt 12, Bild 1 von 3 Samsung Juke Outer Casing Replacement, Keyboard: Schritt 12, Bild 2 von 3 Samsung Juke Outer Casing Replacement, Keyboard: Schritt 12, Bild 3 von 3
    • Open/swivel the phone so the back of the LCD panel is visible.
    • Use the iFixit opening tool to pry the keypad from the hinge on the back of the device.
    • A moderate amount of force may need to be applied.
  13. Samsung Juke Outer Casing Replacement, Click Wheel: Schritt 13, Bild 1 von 2 Samsung Juke Outer Casing Replacement, Click Wheel: Schritt 13, Bild 2 von 2
    • Using your fingernail, remove the stickers covering the screws on the back of the LCD casing.
    • Remove six 3.5 mm screws from the back of the device using a Phillips #00 screwdriver.
  14. Samsung Juke Outer Casing Replacement: Schritt 14, Bild 1 von 3 Samsung Juke Outer Casing Replacement: Schritt 14, Bild 2 von 3 Samsung Juke Outer Casing Replacement: Schritt 14, Bild 3 von 3
    • Using a generous amount of force, use your hands to pry loose the casing from the LCD panel.
    • If necessary, use the iFixit opening tool to completely free the casing.
    • Be careful not to sever the wire connecting the outer casing to the display board.
  15. Samsung Juke Outer Casing Replacement: Schritt 15, Bild 1 von 3 Samsung Juke Outer Casing Replacement: Schritt 15, Bild 2 von 3 Samsung Juke Outer Casing Replacement: Schritt 15, Bild 3 von 3
    • Using the iFixit opening tool, remove the click wheel from the board.
    • After you have freed the edges, use the spudger to release the clip holding it flush to the board.
  16. Samsung Juke Outer Casing Replacement: Schritt 16, Bild 1 von 3 Samsung Juke Outer Casing Replacement: Schritt 16, Bild 2 von 3 Samsung Juke Outer Casing Replacement: Schritt 16, Bild 3 von 3
    • Unlock the ribbon connection by pressing down on the black clip.
    • Carefully pull the click wheel away from the device.
  17. Samsung Juke Outer Casing Replacement, Outer Casing: Schritt 17, Bild 1 von 2 Samsung Juke Outer Casing Replacement, Outer Casing: Schritt 17, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    • Using tweezers, grip the red and blue wires that attach the audio earpiece to the outer casing and pull.
    • This is glued on so a moderate amount of force may be needed.
Abschluss
2 weitere Personen haben diese Anleitung absolviert.
Ryan Turner
107 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-18, Maness Spring 2010 Mitglied von Cal Poly, Team 6-18, Maness Spring 2010
CPSU-MANESS-S10S6G18
3 Mitglieder
12 Anleitungen geschrieben
0 Kommentare zur Anleitung
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 21
Insgesamt: 2,402
