Einleitung
A guide to help replace the spring inside of the setting knob on top of the camera.
Was du brauchst
Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
Carefully squeeze the top right corner of the camera and pry off the external cover.
Continue to pull the external cover and it will come off cleanly.
Remove the screws holding the circuit board.
After you remove the screws, carefully remove the circuit board.
Face camera towards you.
Remove the two screws from circuit board on the left side of the lens.
Carefully hold up the circuit board, while it's still connected to the camera.
Remove all five screws that's on top of the camera.
Carefully push up the top of the circuit board.
Pull up flash circuit board from top of camera.
Face the bottom of the Flash Circuit board towards you.
Remove the one screw that's located on the left side of the lens.
Take the flash circuit board and turn it over.
Remove the plastic setting knob.
