Zum Hauptinhalt wechseln
Repariere deine Sachen
Recht auf Reparatur
Werkzeug & Ersatzteile
Einleitung
Flash bulb soldered to circuit board with capacitor, so it is not possible to only replace flash bulbs.
  1. Remove the six external screws from the camera using a Phillips #0 screwdriver. After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera. Be careful, make sure you don't lose the screws.
    • Remove the six external screws from the camera using a Phillips #0 screwdriver.
    • After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
    • Be careful, make sure you don't lose the screws.
  2. Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery. Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
    • Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
  3. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera. Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
    • Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
  4. Carefully squeeze the top right corner of the camera and pry off the external cover.
    • Carefully squeeze the top right corner of the camera and pry off the external cover.
    • If you hear a "cracking" sound. This is normal.
    • Continue to pull the external cover and it will come off cleanly.
    • Be cautious of the flash capacitor. It carries an electrical charge, that may give you an unpleasant shock.
  5. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  6. Carefully pull off the back cover, parts behind the back of the case might fall out.
    • Carefully pull off the back cover, parts behind the back of the case might fall out.
  7. Remove the screws holding the circuit board.
    • Remove the screws holding the circuit board.
    • After you remove the screws, carefully remove the circuit board.
  8. Remove the front cover, it comes off easily. Buttons might fall out when you remove the front cover.
    • Remove the front cover, it comes off easily.
    • Buttons might fall out when you remove the front cover.
  9. Face camera towards you.
    • Face camera towards you.
    • Remove the two screws from circuit board on the left side of the lens.
  10. Carefully hold up the circuit board, while it's still connected to the camera.
    • Carefully hold up the circuit board, while it's still connected to the camera.
    • Remove all five screws that's on top of the camera.
  11. Carefully push up the top of the circuit board. Pull up flash circuit board from top of camera. Pull up flash circuit board from top of camera.
    • Carefully push up the top of the circuit board.
    • Pull up flash circuit board from top of camera.
Abschluss
Ein weiterer Nutzer hat diese Anleitung absolviert.
Adriel
120 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 6-17, Maness Spring 2010 Mitglied von Cal Poly, Team 6-17, Maness Spring 2010
CPSU-MANESS-S10S6G17
4 Mitglieder
5 Anleitungen geschrieben
Kommentar hinzufügen
Statistik anzeigen:
Letzten 24 Stunden: 0
Letzten 7 Tage: 1
Letzten 30 Tage: 3
Insgesamt: 3,860
