Zum Hauptinhalt wechseln
Samsung LN-T5265F Rear Case Replacement
Was du brauchst
  1. Samsung LN-T5265F Rear Case Replacement, Stand: Schritt 1, Bild 1 von 1
    • Lay the TV screen-side down on a flat, soft surface.
    • Remove four Phillips screws attaching the stand to the TV.
    • Slide the stand out from the bottom of the TV.
  2. Samsung LN-T5265F Rear Case Replacement, Rear Case: Schritt 3, Bild 1 von 2 Samsung LN-T5265F Rear Case Replacement, Rear Case: Schritt 3, Bild 2 von 2
    • Remove fifteen Phillips screws securing the rear case to the front.
    • If present, remove four Phillips screws for the VESA mount.
    • Carefully lift the rear case upwards to separate it from the frame of the TV.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Steven Carlton
606 Reputation
3 Anleitungen geschrieben
Ein Kommentar
The guide says that 15 Phillips screws have to be removed from the back. The actual number of the Phillips screws is indeed 15. However, the supplied picture marks locations of 14 Phillips screws only. The 15th screw is located near the left edge of the rear connector cluster. It has to be removed as well.
Andrey - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 6
Insgesamt: 2,400
